Activity › Forums › Apple Final Cut Pro › Performance issues with 50+ events
Posted by James Bayliss-smith on March 22, 2013 at 3:15 amWill FCPX run better with 1 mega event or 50 smaller events. I’m on a MacBook Pro with 2.93 GHz Intel Core 2 Duo 8GB Ram. I’m struggling at the moment a little under the strain of my news archive.
Is the next version likely to run better on my setup or am I fighting a losing battle here.
Cheers
Loren Risker replied 13 years, 5 months ago 7 Members · 7 Replies -
Bret Williams
March 22, 2013 at 4:07 amI think the problem here is RAM. 8 isnt that much. Core2Duo probably isn’t helping.
Steve Connor
March 22, 2013 at 9:01 amWhat drives are you using?
Steve Connor
There’s nothing we can’t argue about on the FCPX COW Forum
Jeremy Garchow
March 22, 2013 at 12:40 pmIt sounds to me like you might need a media asset manager.
50 Events is the equivalent of 50 projects in fcp7, which is a lot, especially for the older hardware you’re running it on.
Do you need access to all 50 at once or could you use event manager x to load only what you need at the time?
James Bayliss-smith
March 22, 2013 at 12:46 pmThanks Everyone. I am running these events off a firewire 800 external. I do use event manager x, at the moment I have all the events open as I am sorting through a load of stuff. FCPX takes an age to load everything up but the real problem comes when I want to move a clip from one event to another. When I do that it has to load every single event before it copies. Once I haver loaded up all the events I can copy no problem but initially I have to wait around 10 minutes before I can move a clip successfully from one event to another. Once the initial load is done I can move clips around no worries. It’s almost as if FCPX doesn’t load everything up until it needs to. Can anyone explain this behaviour?
James
David Battistella
March 22, 2013 at 1:52 pmI think it is a RAM issue. * is the bare, bare bare minimum to make the program run, and so you need more to do the real heavy lifting.
I bought extra RAM from OWC and it makes a world of difference in large projects.
It scares me to think you have all that media on a FW 800 drive. Is it backed up?
David
______________________________
The shortest answer is doing.
Lord Herbert
https://www.davidbattistella.com -
T. Payton
March 22, 2013 at 4:28 pmI think the Firewire 800 drive is probably adding to the issue too. When working with FW I keep my loaded events to a minimum.
T. Payton
OneCreative, Albuquerque -
Loren Risker
March 22, 2013 at 9:30 pmI edit on a macbook pro 13″ so always struggling with performance. 1 mega event is way better than lots of small events.
OutOfFocus.TV – Original series, music videos, and entertainment for your couch.
