Activity › Forums › Adobe After Effects › Perfectly center anchor point in 3D object
  • Perfectly center anchor point in 3D object
    Posted by Dustin Parsons on September 7, 2012 at 10:23 pm
    Is there a way to have the anchor point perfectly centered in a 3D shape layer? I hate having to just eyeball anchor points which is pretty much the only answer I’ve seen when searching about this.
    Thanks in advance!
    Roland R. kahlenberg replied 14 years ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    September 8, 2012 at 1:53 am
    CS6 has a new feature that allows you to snap any layer’s Anchor Point to its edges or center. You select the Anchor Point Tool (also known as the Pan Behind Tool previously) and depress the CTRL (Command on Mac) and move the ANchor Point towards the center and it’ll just snap into place.
    FWIW, this technique works for 2D and 3D layers.
    You can do this numerically too if you Reset Transform>Anchor Point & Contents>Transform:(shape type)>Position.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
