Activity › Forums › Adobe Photoshop › pen tool
  • pen tool
    Posted by Benjamin Bernard on December 18, 2007 at 3:53 am
    sorry guys this is a very basic question but is there a good tutorial out there that explains how to use the pen tool well in adobe photoshop i am trying to move the vertices of the shape i drew and am becoming very frustrated because i cant move them where i want thanks for your time
    Vincent Rosati replied 18 years, 9 months ago 2 Members · 1 Reply
  • Vincent Rosati
    December 19, 2007 at 2:55 am
    Click on the object path with the Direct Selection Tool (A) to activate the points.
    Use the Path Selection Tool to move the whole object.
    When a curved point is selected with the Direct Select Tool (A), you can grab the end of the handlebar to adjust the curve.
    You can also adjust a curved path by clicking on it, between two points.
    In the Pen Tools, you’ll find the Convert Anchor Point Tool. Click on a curve point to make it into a corner.
    Click and Drag on a corner point to make it into a curve.
    You can also use this tool to adjust the corner angle of a point by using it to grab a point’s handlebar.
    By pressing Alt you can quickly switch this into the Direct Selection Tool
    Vince
    ~The files are INSIDE the computer?
