Activity Forums Storage & Archiving Pegasus 1st generation R4 replacement drives
  • Pegasus 1st generation R4 replacement drives
    Posted by Doug Moore on September 4, 2015 at 11:38 am
    Has anyone used the Seagate Baracuda that are approved for the Pegasus 2 R4 on a first generation Pegasus R4?
    Some support techs have suggested that the Seagate replacement drives that are compatible with the Pegasus 2 R4 have a high failure rate if used with the Pegasus R4 1st generation raid system, others say this is nonsense.
    So I am just checking to see if anyone here has had success using drives approved for the Pegasus2 R4 in a Pegasus R4 1st generation system.
    Thank you.
    Rainer Wirth replied 10 years, 10 months ago 2 Members · 1 Reply
  • Rainer Wirth
    October 26, 2015 at 6:46 pm
    Hi Doug,
    I don’t think its the drives. If they are certified for use with pegasus, then they should be fine. I think its the controller within the pegasus making the difference between first and second generation.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
