Activity › Forums › Adobe Illustrator › PDF loads wrong content?
  • PDF loads wrong content?
    Posted by Chantal Gfeller on August 22, 2018 at 1:36 pm
    Dear co-cows
    i got a problem. (obviousely)
    there’s an illustrator-file that’s supposed to be a kind of presentation.
    every layer acts as a page/slide. within those layers/slides are groups with pictures, frames and text etc.
    when i save it as a pdf and try to open it, it doesn’t load everything at once (example: for slide one it loads pic 1 then pic 2…) and sometimes even content that has been removed from the project but used to be in a certain place. but only for a rlly short amount of time then the actual picture appears.
    does anybody know this issue or knows what to do?
    I’d appreciate all of your experiences!
    Greets
    Kalleheikki Kannisto replied 8 years, 1 month ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    August 24, 2018 at 3:37 pm
    Something to try: I seem to recall that Acrobat used a method of saving where information was simply added to the end of the file if you saved with a simple control-S and you had to actually do something like select “save optimized” or “save as…” to purge the extra information. Perhaps this is the issue here? I don’t know if that applies to PDF saved from Illustrator, or if that even applies these days, but that’s what came to mind.
    Senior Graphic Designer
