Activity › Forums › Adobe Encore DVD › Pdf in dvd menu
Pdf in dvd menu
Posted by James Kelly on October 17, 2008 at 12:32 pmIs there anyway of having a button in encore to launch a pdf file if the dvd is played on a computer?
Any help would be much appreciated.Matthew Hamby replied 17 years, 10 months ago 3 Members · 3 Replies -
Joe Bowden
October 17, 2008 at 8:10 pmNot with Encore alone. You can add the PDF in the ROM folder, and then provide the viewer with instructions on how to access it.
Matthew Hamby
November 3, 2008 at 7:34 pmI was under the assumption that this was possible. So this program cannot make a generic ‘VTS’ number similar to DVD Studio Pro?
Matthew Hamby
November 3, 2008 at 8:19 pmOr you can get eDVD. You add the PDF’s to the encore project via DVD-ROM content. Once you are finished with your DVD, you need to build it as a DVD Folder.
Once finished, there will be a VIDEO_TS folder in this Master DVD Folder. You will use this as your Video_TS for your eDVD project. The chapter points show up in eDVD and you can link them to HTML’s, or documents that are opened upon clicking the button by the user.
