Activity › Forums › Panasonic Cameras › PCMCIA Card Readers
PCMCIA Card Readers
Posted by Shawn Miller on June 14, 2007 at 10:04 pmCan anyone tell me if it’s ppossible to use a non-Panasonic PCMCIA card readers with P2 cards? I would really like to add a single (or double) card reader to my main workstation, but I’m not sure if such a device would need a Panasonic driver to see the P2 card.
Shawn
Shawn Miller replied 19 years, 3 months ago 7 Members · 14 Replies -
Shane Ross
June 14, 2007 at 10:14 pmTo read P2 cards, you either need a G4 Powerbook, PC laptop with PCMCIA slots, or the Panasonic readers. No off brand reader can read the P2 card format.
Shane
Littlefrog Post
http://www.lfhd.net -
Barry Green
June 14, 2007 at 11:42 pmYou can get a $70 PCI->PCMCIA adapter that fits in the back of a workstation and allows using PCMCIA cards. The P2 cards would work in that, I’m sure, but I’ve only seen these products available for Windows systems, I don’t know if one exists for Mac desktops.
Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db) -
Barry Green
June 14, 2007 at 11:43 pm(and to further what Shane’s saying): no USB or firewire reader is going to work, other than the Panasonic ones. The direct PCI slot connection types will work in a desktop, or the Duel Adapter will work for an ExpressCard slot, but if you want to use USB or firewire then it has to be the Panasonic readers.
Axelsasso
June 15, 2007 at 12:46 amLook about a third down the page. This company claims it reads P2 cards.
https://www.psism.com/reader.htm#PCI
Good luck.
sn48
Shawn Miller
June 15, 2007 at 5:44 amThanks Barry,
I’m going to give it a try. I found some inexpensive card readers that have Mac and Windows drivers
https://www.synchrotech.com/products/card-rw_00.html
If it works, I’ll have a cheaper way to offload data from my P2 cards. If not, I won’t have spent a fortune to find out. 🙂
Shawn
David S.
June 15, 2007 at 2:20 pmRemember, an external must be 32-bit. I don’t see any there that are.
I also don’t see any PCI cards that are Mac compatible
Arnie Schlissel
June 15, 2007 at 3:07 pm[axelsasso] “Look about a third down the page. This company claims it reads P2 cards.
” target=”_blank”>https://www.psism.com/reader.htm#PCI”
It has to be installed into a PCI slot on a windows desktop.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Shawn Miller
June 15, 2007 at 4:07 pmAh quite right, thanks for pointing that out… but doing some quick searches, I found a few devices that might work:
https://www.siig.com/product.asp?query=PCI+to+PC+Card-M&pid=982
I’m sure I can find more suitable hardware. Like I said, I’m going to give this a try and let everyone know if it works.
Shawn
Barry Green
June 15, 2007 at 4:49 pmThe only one on that first page you linked to that will work is the EXP34-DA-001, which is the same as the Duel Adapter.
The PCI-to-PCMCIA adapters will work, but those are only for desktop systems, not laptops. But yes those will work, and that $139 one claims to offer a front slot, so that’d be the best pick if it actually works!
Chris Baldwin
June 18, 2007 at 9:18 pmShawn I’d like to know if the Mac PCI card adapter works as well. I wonder if there is also a extension cable that has a PCMCIA male on one side to go into the back of the tower and a PCMCIA female adapter on the front … so that you could insert and remove cards from the front of your workspace instead of behind the tower.
I just can’t believe there is no way to transfer content off the P2 cards via the camera’s firewire or usb2 ports. I have dne it through FCP capture window but that’s not at all what i’m trying to do…
Am I wrong? Is there some means of connecting the HPX500 or HVX200 to a laptop or tower and transfering content to other hard drives?
when do you expect to know about the SIIG PCI to PCMCIA adapter?
