Activity Forums Apple Final Cut Pro Legacy PC user switching to Mac and FCP
  • PC user switching to Mac and FCP
    Posted by Chris Barnard on June 20, 2011 at 10:14 pm
    Hi all,
    I’ve been using Adobe and Edius on PC’s for some time now and have never used FCP.
    I’ve been asked to shoot a large project and I need to switch to FCP for my clients.
    I also need to upgrade my cameras. Essentially I am required to edit in FCP and the footage I will shoot will have to be full 1920 (no HDV!) and be no less than 35Mbps.
    Currently I am shooting 1440 at 25Mbps (Sony Z5). I am thinking I will keep my Sony Z5’s, and add the nano flash to the three cameras I have, so I will shoot in 1920 and at about 100Mbps.
    My question is: Can I use a Macbook Pro for this task? – I will be travelling at lot whilst editing and I don’t want to be tied to a desktop.
    I’m NOT going to be doing much graphic work or working with effects on the video streams. I will need to edit 3 streams in a multicam setting. I understand that FCP can automatically set a proxy file at the highest level for the macbook’s specs.
    I was thinking that I would purchase the highest spec’d macbook pro and this might get the job done. Am I right?
    Chris
    Jerry Hofmann replied 15 years, 3 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 21, 2011 at 1:51 am
    I should think it would work fine, as long as your scratch disk setup is fast enough. Right now, you’d want the 17″ machine so you could add a fast eSATA array to it.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
