PC-Pro Res Issues with Premiere
Hey guys,
I have been having an issue with certain pro res files for a while now.
I have quick time installed so I can use pro res files made in compressor without a hitch.But when I use a pro res file made from log and transfer inside final cut. Adobe cant play the file, and VlC will only play the audio.
Does anyone know a way to fix this without having to run everything through compressor?
