Activity Forums Adobe After Effects PC Pro Res Agony
  • PC Pro Res Agony
    Posted by Terry Hahin on June 26, 2014 at 9:29 am
    Hello All,
    This is a highly talked about for years, but I have yet to find a solution for me.
    I’m a PC After Effects User. Have many clients who are passing off pro res content to me. It is a much bemoaned fact online that After Effect causes gamma shifts when it decodes Pro Res. In all my searches I’ve discovered only two solutions:
    1. Export the file back out to Pro Res
    2. Export content back out to YUV uncompressed 8/10 bit
    But both these only work on a MAC.
    The Fact that both have a YUV color space makes me think that is a direction to think….but I don’t know any YUV output options on PC.
    I use PR Helper for PC to create Pro Res files, so that is not a problem. PR Helper causes no major gamma shift. The problem resides in After Effects Pro Res Decoding for sure. But I need an uncompressed intermediate codec in PC based After Effects that doesn’t muck up my outputs.
    Thanks to anyone who can help.
    Terry Hahin replied 12 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
