Activity Forums Adobe Premiere Pro PC performance bottleneck
  • PC performance bottleneck
    Posted by Eric Monroe on July 10, 2009 at 6:33 pm
    I have read quite a few posts on the forum, w/o a real straight forward answer to my issue. Many posts say “CS4 HELP” as their title, so if this has been answered I apologize in advance.
    I shoot quite a bit of ballet/dance recital jobs. I use a qty. of 4 standard def. 3ccd panasonic mini-dv cameras. The need for ppro’s multi-cam feature is of course evident in what i do. Recitals are shot in 2 parts so I setup separate seq. in ppro to edit the first half and the 2nd half. Each sequence contains 4 tracks of video/audio that and they are never more than 45-60 min. in duration. I have been using multi-cam in ppro CS2, CS3 and now CS4 for going on 3 years.
    Here is my issue:
    Since moving to CS4, multi-cam editing has become jumpy, jittery (whatever adjective you wanna place there) and it is making my job, let’s just say……NOT SO MUCH FUN. :o) My machine screams though everything else. After struggling through the multicam edit, I can go back out of the multicam window to the sequence and playback the edited multicam timeline without problem. It only jitters in the multicam window itself. I run windows/applications on my C drive and use the other drives to place to footage and scratch disks. I have heard that Raid zero setups have increased speed for HD editors. However I am struggling to understand why I would be having a bottleneck in my workflow when only editing mini-dv footage. My editing machine, in my humble opinion is no slouch by any means.
    So question of the day…….. why do I have jumpy playback….and what is causing it?
    My setup is as follows:
    Windows 7 64-bit RC (fresh install with updated drivers)
    Intel core 2 duo 6600 2.4 ghz
    8 gig DDR2 ram
    EVGA Motherboard (would have to look up the model cuz I don’t remember)
    2 WD 250gb HDD 7200 rpm e-sata2
    2 WD 500gb HDD 7200 rpm e-sata2
    Nvidia 8800 GTS card
    I direct live productions at work, and when I switch live to a camera on my video switcher, it just goes live…it doesnt jump around and lock up…..and I assume that is the general idea with adobe’s multicamera editor. I cant take much more of this…..it is very difficult to make good cuts, when it skips around this way….which in turn kills workflow.
    I would appreciate any help that could be given.
    (side note)….i imported one of my projects into a friend’s new 13″ macbook pro with only 2 gig of ram and running OSX 10.5/CS4 software/raw footage and the project/scratches all off the single internal HDD drive…….and it doesnt skip at all. anywhere. it powers through the multicam edit like it is nothing. same proj, and footage that my editing PC chokes on.
    Brian Louis replied 17 years, 1 month ago 2 Members · 2 Replies
  • Eric Monroe
    July 13, 2009 at 4:26 am
    I could really use some help with this issue……ANYONE?!?
  • Brian Louis
    July 14, 2009 at 5:25 pm
    Windows 7 ??
