Activity › Forums › Maxon Cinema 4D › PBR light rotation problem
  • PBR light rotation problem
    Posted by Maicol Persiani on January 31, 2019 at 12:08 am
    I am following a tutorial online and while doing the lighting I am having an issue.
    In the video tutorial the guy is rotating the PBR lights and the axis are rotating with the white panel and the the light is pointing at the object. But when I try to rotate my lights the panel rotate but the axis remain the same and the result is obviously different.
    It’s like the light is still pointing following the axis and not the rotation.
    What should I unlock or fix in my settings?
    Brian Jones replied 7 years, 8 months ago 2 Members · 1 Reply
  • Brian Jones
    January 31, 2019 at 3:00 pm
    can you post the scene?
