Activity Forums Adobe After Effects “Pause” a position keyframe animation for a composition?
  • “Pause” a position keyframe animation for a composition?
    Posted by Rick Dane on October 14, 2009 at 3:48 am
    This may sound a bit weird but its for a web application demo so what I am trying to do is mimick the user interaction with what would be the application…. I have a slide reel of products that is in a composition and is set with a simple position keyframe to scroll across the screen left to right..
    What I would like to do is pause this in the middle of the path for a set amount of time without having to manually divide it into 2 separate animations since this would make it more difficult to maintain the constant velocity and would basically just be at time saver overall for these types of projects.. I’m wondering if there is a way to do this..
    What would happen when it pauses is that it would show a separate animation where one of the products enlarges and shows more info about that. (just to give you a fully picture of what I’m doing)
    Rick Dane replied 16 years, 10 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    October 14, 2009 at 6:36 am
    Would it be as simple as using a Hold keyframe? I think Aaron has a tutorial on this at the COW. Otherwise, use the Help docs.
    Cheers
    RoRK
    Sell your AEPs with broadcastGEMs’ DVD series of templates. Click here for more
  • Rick Dane
    October 14, 2009 at 6:50 am
    Thanks, yeah that sounds like it’d work, I have been trying to use the help docs but not knowing terminology its hard to search for specifics things like this 🙂
