Activity › Forums › Adobe Illustrator › Pattern Gap
  • Pattern Gap
    Posted by Wanda Muench on July 31, 2011 at 4:58 am
    Hi, I did find a post that addresses my question but wasn’t really answered–OP just had a ‘workaround’.
    Sometimes when I create a pattern using a clipping mask to remove extraneous bits outside of the square (that will be the swatch), the resulting swatch has a lot of white space around it and the pattern doesn’t abut–the repeating images have blank spaces around them.
    I am simply using unadulterated vector lines and shapes for the pattern–no raster–and an unstroked unfilled square.
    Any clues as to why?
    Wanda
    Tylor Larson replied 15 years, 2 months ago 2 Members · 1 Reply
  • Tylor Larson
    August 1, 2011 at 7:02 pm
    if you use a clipping mask, the element are still captured in the pattern. look at your tile in outline mode to get a better understanding of the issue. i always check my pattern in outline mode before dragging it to the swatch palette.
    the shortcut for outline mode is Cltr+Y and hit it again to go back.
    I hope this answers your question. if not flame away
