Activity Forums Adobe After Effects Expressions pathpoint to pathpoint expression
  • pathpoint to pathpoint expression
    Posted by Alex Weil on December 9, 2019 at 5:38 pm
    hey,
    i got 2 Ellipses and one path with 4 points on the same Shape layer. now i want to connect the first 2 Pathpoints of the Shapelayer to the first and third Pathpoints of the first Ellipse. With the last 2 Pathpoints of the Path i want to do the same with Ellipse number 2. so i tried to write this expression, but i failed.
    var targetPath1 = content("Ellipse 1").content("Path 1").path;
    var targetPath2 = content("Ellipse 2").content("Path 1").path;
    createPath(points = [targetPath1[0], targetPath1[2], targetPath2[0], targetPath1[2]], inTangents = [], outTangents = [], is_closed = true)
    any suggestion?
    cheers
    Alex
    Alex Weil replied 6 years, 9 months ago 2 Members · 4 Replies
  • Dan Ebberts
    December 9, 2019 at 5:55 pm
    I think you just need to change the way you’re accessing the points on the ellipse paths. From this:
    targetPath1[0]
    to this:
    targetPath1.points()[0]
  • Dan Ebberts
    December 9, 2019 at 5:59 pm
    Also, I noticed that the 4th point you reference is from targetPath1, but it should be for targetPath2.
    Dan
  • Alex Weil
    December 10, 2019 at 8:49 am
    just wow ☺ thanks Dan
    i made this now, and it kind of works.
    createPath(points = [targetPath1.points()[0], targetPath1.points()[2], targetPath2.points()[2], targetPath2.points()[0]], inTangents = [], outTangents = [], is_closed = true)
    the Points dont line up very well, do i have a toComp() somewhere?
  • Alex Weil
    December 10, 2019 at 9:00 am
    ahh okay, i figured out that the expression just reacts to the path but not to the transformation of the Ellipse. Maybe i need to find a way to calculate this in
