Activity Forums Adobe Illustrator Path offset problem
  • Path offset problem
    Posted by John Daren on August 11, 2016 at 1:37 pm
    Hi, I’m trying to make my image 0.1mm larger. When I select it and go to Object>Path>Offset Path, I can create the offset. The problem is that it creates a negative path as well as a positive path. How can I just have the positive (outside, expanding) path?
    The object is a simple square, which is completely closed
    John Daren replied 10 years, 1 month ago 1 Member · 1 Reply
  • John Daren
    August 11, 2016 at 8:54 pm
    I found the answer. The file was exported from Solidworks. It needed to be released from a compound path, and then ‘joined’ first.
