Activity › Forums › Adobe After Effects Expressions › pasting illustrator paths to position keyframes in AE7
  • pasting illustrator paths to position keyframes in AE7
    Posted by Rob Kahn on February 10, 2007 at 5:20 am
    This worked fine in AE 6.5 but I’m having trouble pasting illustrator paths as position keyframes in AE 7.0. Am I missing a new trick or an old one?
    Rob
    Julio Crespo replied 19 years, 7 months ago 3 Members · 2 Replies
  • Brian Charles
    February 10, 2007 at 4:29 pm
    Are you selecting the word “position” for the layer. This works for me.
    I’m using Illustrator CS2 and the File Handling Prefs are set to AICB (Adobe Illustrator Clip Board).
  • Julio Crespo
    February 12, 2007 at 2:59 am
    This Happen to me just a few days ago. I copy all the points of the path, with the direct selection tool in Illustrator. But when I go to AE, the “paste” option was disable, no matter what layer or property I select. The solution…. Close and reopen both Application
