Activity › Forums › Maxon Cinema 4D › Pasting and Object with textures
  • Pasting and Object with textures
    Posted by Robyn Rhodes on May 10, 2011 at 10:49 pm
    Hi Kollegen,
    Is there a way to paste an object from one open project to another WITH the textures?
    Also…
    Is there a way to replace objects that have been animated already?
    I am doing several animation with different cell phones. Would be great to able to replace the object once animated with the textures.
    Robyn
    I’m only half the thing I say I am, the other half are me.
    Randy Johnson replied 15 years, 4 months ago 2 Members · 3 Replies
  • Randy Johnson
    May 11, 2011 at 6:22 am
    You want to read up on X refs for swapping your phones.
    Your textures should be following…
    /Randy
  • Robyn Rhodes
    May 11, 2011 at 2:07 pm
    any quick study resources for Xrefs? Does it work for keyframes?
  • Randy Johnson
    May 11, 2011 at 2:13 pm
    Well, I have not done much with Xrefs since I just recently started using them but you pretty much make a model, rig, animate and save the file. Then in your “master” project use an x ref, link the file and change your offset time to where you want it.
    /Randy
