Activity Forums Adobe After Effects Paste mocha shape from Mocha AE cs6 to AE Problem Pr involved
  • Paste mocha shape from Mocha AE cs6 to AE Problem Pr involved
    Posted by Louis Hou on March 6, 2014 at 11:30 am
    Hello all!
    Here’s what bothers me:
    First I select a piece of video clip (MP4) which is cut in Premiere Pro CS6, then File -> Replace with after effects composition;
    In AE, I choose Track in mocha AE.
    When I try Paste mocha mask, only the first frame of the mask pastes. When I paste only the data to the composition, nothing changes at all. I paste the data in a text file to find that the numbers are relatively the same.
    I know there are many similar asked questions, but no answer really helps me. I already checked Frame rate and in-out points settings. When I export video file in Premiere (without using “replace with ae composition”) before tracking, everything works fine.
    Any help will be appreciated!
    Thanks all.
    my e-mail: dukehyh888@hotmail.com
    Louis Hou replied 12 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
