Activity Forums Apple Final Cut Pro Legacy Paste attributes (just black/mid/white color)
  • Paste attributes (just black/mid/white color)
    Posted by Arturo Glass on March 14, 2014 at 1:18 am
    Is there a way to remove and replace all of the white balance settings in clips that already have the 3 color corrector done? I’ve got a bit of a pink hue across a bunch of shots and want to batch remove this, but already set saturation and black/mid/white levels as I like. I was able to remove it in one shot by adjusting the color balance through the 3 color wheels, but don’t know how to just copy and paste this.
    Mark Suszko replied 12 years, 5 months ago 3 Members · 4 Replies
  • Shane Ross
    March 14, 2014 at 1:37 am
    You can’t. You can only copy and paste the full filters…not just attributes from them. Sorry.
    Shane
    Little Frog Post
  • Mark Suszko
    March 14, 2014 at 1:49 pm
    There is no law that says you can only invoke ONE 3-way color corrector. Go make the correction to one clip using a second instance of the TWCC.
    See that little icon of the hand on the frames? You can drag that icon onto any other clip and apply the changes to it. So just motor over to the clips that need the extra level of correction and drag-and-drop, based on the first clip you corrected by hand. I have been able to drag and drop like this on multiple selected clips at a time, but not always with perfect success.
    Anyhow, this may help you add secondary CC in tint while leaving the other settings alone.
  • Arturo Glass
    March 14, 2014 at 5:06 pm
    Good idea. Thanks. I just wasn’t sure if doing that would somehow be pushing colors out of a safe zone or making the image too muddy. But I guess that’s just a matter of looking and deciding.
  • Mark Suszko
    March 14, 2014 at 6:40 pm
    It may or may not work but do please tells us, either way.
