Activity Forums VEGAS Pro Passthru VHS>CamCorder>Vegas Problem
  • Passthru VHS>CamCorder>Vegas Problem
    Posted by John Gregoriades on February 16, 2006 at 4:47 pm
    Hello, here is the setup:
    A firewire hookup VHS player > Sony Digital Camcorder > Firewire > PC 3.4GHz, 2G RAM, Windows XP SP2 + Vegas.
    Capture works when a digital casette is played on the Camcorder.
    Capture does not work when a VHS tape is played as a passthru.
    Details:
    A. Capturing Digital-8 works but “Preview Suspended During Capture.” Cannot see what’s going on except on the counter. I can’t find the control to show the Video on the monitor during capture.
    B. Capturing as “passthru” the audio is OK, but shows a very brief (fraction of a second) moving video, then turns blank. “Reconnect the device” does the same. Rebooting, different firewire plugs etc. no luck.
    Advice sought!
    Thank you,
    John
    John Gregoriades replied 20 years, 6 months ago 2 Members · 4 Replies
  • Edward Troxel
    February 16, 2006 at 4:53 pm
    In the capture program, turn OFF “Device Control”. What’s happening is the capture program is trying to start playing your tape (and you’re not using one). Turn off Device Control and all will work fine.
    Edward Troxel
    JETDV Scripts
  • John Gregoriades
    February 16, 2006 at 5:22 pm
    While searching (before I bothered folks like you in this forum) I came across the device control, but cannot find where it is! Sorry, it must be under my nose. Where is it, please?
    John
  • Edward Troxel
    February 16, 2006 at 7:16 pm
    Capture program – Options – Preferences and it’s the very first option on the GENERAL tab.
    Edward Troxel
    JETDV Scripts
  • John Gregoriades
    February 17, 2006 at 10:36 am
    thank you, Edward.
    As I said, it was right under my nose. I un-checked it and it worked just fine as you said. Many thanks!
    John
