Activity › Forums › Adobe Photoshop › passport photos
passport photos
Posted by Anthony Faulkner on February 2, 2010 at 11:49 pmHow do I resize a large JPG into a passport size photo without it getting super pixelated?
thanks
Christina Rodriguez replied 16 years, 3 months ago 5 Members · 4 Replies -
Paul Benson
February 5, 2010 at 1:51 amWith today’s cameras I would imagine you have plenty of resolution so as to avoid pixelization.
First, I would make sure the picture is 300dpi. It is done through a dialog box, Image->Image Size, I believe. When you change the dpi, the dimensions will change for the image, but you are not losing any pixels.
If the image is exactly what you want, then you can use the same dialog box to set the dimensions and you should be done.
If not, next I would turn on the rulers to use as a reference, since the passport photo needs to be a specific size. If you know how to drag down guidelines from the rulers do that (it’s easy, just click in the ruler and drag into the document. A line should appear, but it will not be part of the true picture).
Then you should shrink the picture to fit into the correct dimensions. You can shrink it either by using the transform function (Ctrl-T) or using Image->Image Size. You can crop the picture if it makes it look better. The pixelization should not be a problem.
Pauley
John Mensinger
February 5, 2010 at 12:32 pmAlso, when resampling to smaller sizes, choose the method “Bicubic Sharper” at the bottom of the Image Size dialog box.
John M:
All of the vim with none of that annoying vigor. -
Richard Harrington
February 21, 2010 at 2:06 amSelect Crop tool
Type in size into Options bar and set resolution of 200 ppi
Crop
Richard M. Harrington, PMP
Author: Video Made on a Mac, Photoshop for Video, Understanding Adobe Photoshop, Final Cut Studio On the Spot and ATS:iWork
Christina Rodriguez
June 19, 2010 at 12:38 amEasy… (assuming this is a High Res Photo)… with the crop tool selected, at the top (under your menu) there should be some areas where you can input numbers… Type in the width in inches (example: 3 in) and height (in inches) that your picture need to be. And in DPI (or resolution) type 300.
Then crop the image, making sure your head is where it is supposed to be and it will shrink it down.
You need to follow certain directions for passport photos, that you can get from the US government website. Just search “passport photo instructions”
C.R.
