Activity Forums Maxon Cinema 4D Pass PSR from Hierarchy to other Hierarchy
  • Pass PSR from Hierarchy to other Hierarchy
    Posted by Corrado Carlevaro on June 10, 2016 at 11:09 am
    I have a Hierarchy of joints passing their positions to points in a spline:
    Hierarchy -> Object Index -> Joint.01 (Position)-> (Spline) Point (Point Position)
    I want the same Hierarchy to pass PSR to another Hierarchy of Objects:
    Hierarchy -> Object Index -> Joint.01 (PSR)-> …….. -> Hierarchy.2 -> Object.01 (PSR)
    I don’t know how to do that; if I just try to connect Joint.01 Position Output to Object.01 Position Input all the Xpresso becomes yellow. The Hierarchies have same number of objects, the only difference is the 1st is a joint chain, with Down iteration, the 2nd is a normal list, with Next iteration.
    Thank you for your help
    Corrado
    Corrado Carlevaro replied 10 years, 2 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 10, 2016 at 7:24 pm
    Try using a Character>Retarget tag.
  • Corrado Carlevaro
    June 11, 2016 at 3:57 pm
    Thank you, nice tip, I didn’t know Retarget Tag, but it looks like you need the very same hierarchical structure to make it work:
    let’s say I have a “tentacle” joint chain (nested) and I want a group (list) of spline cross sections in the same global positions of joints to put in a Loft Nurbs and generate the tentacle mesh, can I use the Retarget tag?
    I ended up cloning the cross sections on the spline generated by the joint chain (which is the best solution because spline has intermediate points) but, for future use, I wanted to know if it is possible with Hierarchy nodes (they confuses me a bit)
    Corrado
