Activity Forums VEGAS Pro Parts of audio is distorted on DVD and AC3 problem
  • Parts of audio is distorted on DVD and AC3 problem
    Posted by John Thom on June 21, 2005 at 6:34 am
    In my Vegas project, the audio never surpasses 0 db. I rendered it as a WAV for PCM audio. Depending on what program I use to view the DVD, I get different distortions of the audio, such as the volume being reduced during a loud part of music. What could be the problem?
    Also, when I render the audio (some parts are 48 khz and others are 44.1 khz) as stereo AC3, I get crackles and pops in the audio.
    Thanks a lot.
    -John
    John Thom replied 21 years, 2 months ago 3 Members · 5 Replies
  • Gary Kleiner
    June 21, 2005 at 7:21 am
    Try this:
    In the AC3 Custom settings, set the Preprocessing>Line mode profile to: NONE
    Gary Kleiner
    Vegas Training and Tools.com
  • John Thom
    June 21, 2005 at 2:37 pm
    I’m unable to make that setting change. It gives me a “the custom template you selected is not valid with the current project settings” error.
    -John
  • John Thom
    June 21, 2005 at 3:02 pm
    I’m able to change that setting now–but it didn’t help the audio. The crackling and popping are being experienced when I preview through DVD Architect. Do you think it’ll disappear if I burn it on DVD?
  • Ted Snow
    June 21, 2005 at 8:42 pm
    If you can hear the noises while previewing, chances are they will be reproduced in the final product. Does the noises appear when you play the project from the timeline in Vegas or just after you have rendered to AC3?
  • John Thom
    June 22, 2005 at 1:05 am
    The noises appear after I’ve rendered the sound to AC3.
    -John
