Activity › Forums › Adobe After Effects › particular particles pop off
  • particular particles pop off
    Posted by Lawrence Chandler on August 24, 2018 at 5:06 pm
    Hi all,
    I’m creating some cartoon clouds using Particular and and it’s working great except that no matter how long I set the lifetime, particles keep on randomly dying. I’ve set the death time to the comp length, to twice the comp length. I tried used a script “thisComp.duration * 2” and it still pops. Played with the pre-roll–same result. Since these are large particles (I’m only birthing a few per second) it’s pretty noticeable when a “cloud” suddenly disappears.
    Kalleheikki Kannisto replied 8 years, 1 month ago 2 Members · 3 Replies
  • Kalleheikki Kannisto
    August 24, 2018 at 5:28 pm
    Possibly particles are closer than camera near cutoff?
    Senior Graphic Designer
  • Lawrence Chandler
    August 24, 2018 at 5:50 pm
    I’m not actually using a 3d camera layer in the scene though that’s a good call.
    I think I figured it out. I’m using a textured sprite– a precomp with a shape layer with some wiggle on it’s transforms. Once I reset the time sampling to “Start at birth play once” it seems to be working correctly.
    thanks!
    Larry
    August 25, 2018 at 10:53 am
    Ah, ok, so the texture footage itself run out before the end.
