Activity Forums Adobe After Effects Expressions Particular Emitter to Write-on Problem
  • Particular Emitter to Write-on Problem
    Posted by Jack Sewell on June 13, 2010 at 4:46 pm
    I’m trying to pick whip my Particular emitter to the X,Y position of my write-on effect. However, when I do so, it is offset by quite a long way.
    I’ve tried going through the exact process, but with a very simple square shape for the write on effect. Then it works fine, no off-set problems at all.
    Is this a bug?! I’m using AE CS5, 64-bit on an iMac, with the latest version of Particular.
    Am I missing a trick here?!?!
    Any help would be very greatly appreciated.
    Many thanks,
    Jack
    James Gordon replied 11 years, 6 months ago 2 Members · 2 Replies
  • Jack Sewell
    June 13, 2010 at 4:59 pm
    HA!!!
    It was because my write-on effect was a different size canvas to my Particular effect…………
    Silly me…………..
    …………..and on to it………… 🙂
  • James Gordon
    February 24, 2015 at 10:32 pm
    Just a quick ‘thanks’ for posting the solution you found to your problem.
