Activity Forums Adobe After Effects Particular and transparency behind sprite particles…
  • Particular and transparency behind sprite particles…
    Posted by Steve Dorsey on July 19, 2010 at 9:24 pm
    Hello
    Applying particles to a solid. I made the solid, then applied the plug-in (latest version, CS5). I’m using sprites with assigned layer as the particle.
    The background (between particles) is not transparent. It is the same color as the original solid.
    I need the background to be transparent. How can I achieve this?
    Steve Dorsey replied 16 years, 2 months ago 2 Members · 2 Replies
  • Darby Edelen
    July 19, 2010 at 11:35 pm
    Under the “Rendering” header make sure that the ‘Transfer Mode’ is set to None.
    Darby Edelen
  • Steve Dorsey
    July 19, 2010 at 11:46 pm
    That was not the issue (I have no idea what the issue was).
    I rebuilt the entire comp and it’s working now.
