Activity Forums Adobe After Effects Particular and masking
  • Particular and masking
    Posted by Todd Morgan on November 21, 2006 at 12:59 pm
    Hi there,
    I have a smoke effect for a chimney that works nicely, but I need to matte out the bottom emitter portion so that the smoke looks like it is coming out of the chimney. I tried creating a mask along the chimney front edge to block out the emitter, but it won’t take. Any ideas would be appreciated!
    Todd
    Todd Morgan
    morgancreative
    Todd Morgan replied 19 years, 10 months ago 2 Members · 2 Replies
  • Tobias Pfeiffer
    November 21, 2006 at 1:52 pm
    make a solid layer or use your chimney layer as “obscuration layer” und visibility section of particular. the drawback here is that only 1bit alpha channels are support. hard edges may appear. these layers need to be 3d.
    you can also precompose your particular layer and add the mask afterwards. but nor real 3d obscuration with this technique.
    good luck,
    payton
  • Todd Morgan
    November 21, 2006 at 1:57 pm
    Thanks for your help. I realized that I had set the smoke up on an adjustment layer. Smack me in the head!
    Todd Morgan
    morgancreative
