Activity › Forums › Adobe After Effects › Particular 3Dness
  • Particular 3Dness
    Posted by Chris Poisson on November 20, 2006 at 12:43 am
    How can other objects interact properly with particles from Particular? I have a 2D still that I want to zoom through a particular snowfield. The snowfield is about 750 pixels wide and deep. It looks like a box of snow from a custom view, but the still I want to pass through it always looks on top of it all unless the layer is below the snow layers.
    I have made the still 3D as well and am looking at the whole thing with a custom camera. What’s the trick?
    Mylenium replied 19 years, 10 months ago 4 Members · 6 Replies
  • Todd Morgan
    November 20, 2006 at 1:34 am
    Have you set you snow to be emitted from a layer?
    Todd Morgan
    Creative Director
    Freelance F/X Inc.
  • Steve Roberts
    November 20, 2006 at 3:21 am
    You need to make your other layer an “obscuration layer” in Particular.
  • Chris Poisson
    November 20, 2006 at 4:04 am
    Todd,
    The snow is coming out of three layers, each has it’s own animated custom emitter.
    Steve,
    I have never heard of what you describe, will look into it.
  • Mylenium
    November 20, 2006 at 5:51 am
    Visibility options –> Obscuration layer. Not very obvious, but rather important.
    Mylenium
    [Pour Myl
  • Chris Poisson
    November 20, 2006 at 2:22 pm
    Okay, yes, a big light going on here, now to make it more complicated. The “layer” I want to interact with the particles works great by selecting it in each particle layer (3) as the obscuration layer, that’s sunk in pretty well.
    But when this piece is done, the “layer” will actually be 3 layers, so can I precompose all of them and use the precomp as the obscuration layer in the final piece?
    The “layer” is a photo of two people, I want each face to fly in from behind another background object as separate cropped head shots, fly into place that matches their position in the whole picture, and then have the masks transition to the whole shot so that the two pics become one. All this I want to happen in front of the flakes.
    Am I on the right track?
  • Mylenium
    November 20, 2006 at 6:00 pm
    It may look odd, but it should work. Be aware that “Collapse transformations” will not work in that case. The pre-comp must be one solid 3D layer.
    Mylenium
    [Pour Myl
