Activity Forums Adobe After Effects Particles to be move/sucked to a point on the comp (form).
  • Particles to be move/sucked to a point on the comp (form).
    Posted by Adam Lewen on June 20, 2021 at 11:24 am
    Hi forum.
    A simple question;
    I will end an animation have a starry night look of particles, and wanted to simply have those particle to animate on a slow (few seconds) move/push, toward the yellow square in the attached image
    https://www.dropbox.com/s/j3ql5fjzws0zoxu/starry1.jpg?dl=0.
    right now those particles are via form.
    I anyone could shed light, on what seems to be a simple task, I would be greatful.
    Thank you so much!
    Adam Lewen replied 5 years, 2 months ago 2 Members · 2 Replies
  • Graham Quince
    June 20, 2021 at 11:29 am
    If you’re using Trapcode Particular you can use the Sphere option in the Physics section with a negative displace value.
    In CC Particle World, you could precomp the stars coming out of the point then time reverse the precomp.
  • Adam Lewen
    June 20, 2021 at 11:34 am
    Thanks for the reply.
    Right now I am using form. I am aware of the other methods in what you have mention, and might change. But I am intersted to know if it’s possible in a simple manner, due to this fact…
    I am using form because of a couple of things before I get to this stage.
    Thank you!
