Activity › Forums › Boris FX Particle Illusion › Particles not showing up in Premiere and AE
  • Particles not showing up in Premiere and AE
    Posted by Chris Powers on September 5, 2008 at 1:19 am
    Hey guys. I’ve made my particle effects to line up with my footage. i export the effects with all the alpha options except removing the black BG from the RGB.
    However, when I import into AE or Premiere, the footage is invisible. I can see the footage in windows media player, and it also shows up in AE and Premiere if i ignore its Alpha…only problem then is I’ve got my effects on black.
    I was following the tutorial from the wonder touch website but…no go. Any pointers?
    thanks very much,
    -Chris
    Jose Burgos replied 18 years ago 3 Members · 2 Replies
  • Alan Lorence
    September 5, 2008 at 3:53 pm
    If you load the rendered output back into particleIllusion, do the particles show? If not, the alpha channel is probably empty (not rendering).
    Did you check the “create non-intense alpha” option? If so, and if all of the particles in the project are “intense”, none of them will be added to the alpha channel. This is intended behavior — check the docs.
    Is the render occurring in particleIllusion itself, or in pIRender? If pIRender, you probably need to run pIRender manually and turn off hardware acceleration.
    Alan.
    http://www.wondertouch.com
  • Jose Burgos
    September 6, 2008 at 12:30 am
    Did you choose a file format that has alpha?
    AVI need to be specific as well a still file formats.
    Just making sure in case you did not know this already.
    Take care,
    Jose Burgos
    http://www.burgosfx.com
