Activity › Forums › Boris FX Particle Illusion › particleIllusion 3.0 Emitter Library
Posted by Russ930 on December 18, 2006 at 5:30 amI have downloaded the emitter library but can not open them in Particleilluison.
Can anyone help me out?
ThanksAlan Lorence replied 19 years, 9 months ago 2 Members · 4 Replies -
Alan Lorence
December 18, 2006 at 12:35 pmIf you put them in the “Emitter Libraries” folder then use the “quick load” library list (r-click in the library window) to load another library. You can also use “load library”, or click the bar that is between the library window and the preview window.
Alan.
wondertouch -
Russ930
December 18, 2006 at 9:21 pmThanks, that worked, but can you tell me where the orginal
Library went? -
Russ930
December 18, 2006 at 9:23 pmI figured it out. Is it not possible to have all of the librarys loaded and visable at the same time?
Alan Lorence
December 18, 2006 at 9:54 pmNo. You can use the Library Manager though.
Alan.
wondertouch
