Activity › Forums › Adobe After Effects › Particle world and gravity
  • Particle world and gravity
    Posted by Otto Lindqvist on May 4, 2012 at 11:48 am
    Hello,
    I was doing some particle tests today. Because I was at school I wasnt able to use particular as I would have done at home so I had to use particle world.
    So is that really so that after particles have been emitted I cant change the influence of gravity for those particles. I was trying to reach that kind of thing that the source is animated going on a path which was a text, so it writes the text. And then there is a gravity switch on the side that I animated to go on position (graphical switch. Gravity linked to it with an expression, which seems to be correct) after the text have been written. However when I add some value to the gravity after emitting, nothing happens. But if the gravity is on all the time it influences the particles.
    It’s like this:
    Time:
    0:00 Text is being written. 0:15 text is ready. 0:17 Gravity is switched on -> nothing happens
    I tried it also with keyframes. Not just with the linked expression.
    Thanks. Hope someone understands what I mean….
    -Otto
    If it’s moving, animate it
    Kevin Camp replied 14 years, 5 months ago 2 Members · 1 Reply
  • Kevin Camp
    May 4, 2012 at 4:18 pm
    [Otto Lindqvist] “So is that really so that after particles have been emitted I cant change the influence of gravity for those particles. “
    yep… with particle world, pretty much all of the particle’s ‘determinants’ are set at birth, so you can’t change the influences of a particle after it is born…
    it’s like fate, each particle’s life is predetermined before it is born 🙂
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
