Activity Forums Boris FX Particle Illusion Particle Illusion not running.
  • Particle Illusion not running.
    Posted by Javier Lopez on February 14, 2007 at 2:58 am
    Hello,
    How are you people, I have a big problem, my Particle Illusion was running fine till yesterday, with no reason today, I had tried to run the program but does not respond, I not see anything on the screen, but, when I look in to the “Task manager” under “Processes” PARTICLEILLUSION.EXE is listed there!
    Any advise on this one?
    Thanks in advance.
    Alan Lorence replied 19 years, 7 months ago 4 Members · 5 Replies
  • Elvis Deane
    February 14, 2007 at 5:15 am
    End the process, then in your Start menu program group for pI, run Reset Default Settings, then run pI again. That’s worked for me any time I’ve had any similar hiccup.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    Wilbur of Wumbaberry
  • Craig Cooper
    February 14, 2007 at 5:51 am
    Hey Thanks for that tip. I too HAD this problem.
    Craig
  • Alan Lorence
    February 14, 2007 at 1:04 pm
    I’m hoping I’ve posted this before, but there is a known problem that may cause this:
    If you exit particleIllusion 3 (for Windows only) when the main window Preview window background color is set to “image”, it won’t start up (although it usually gives you one of the Windows “this program has caused an error…” message windows).
    The only way to fix it (in 3.0.1a) is to “reset default settings”.
    Alan.
    http://www.wondertouch.com
  • Javier Lopez
    February 14, 2007 at 1:45 pm
    Hello Alan,
    How can I reset the settings, I can can’t run Particle Illusion.
    Thanks.
  • Alan Lorence
    February 14, 2007 at 1:51 pm
    Did you read Elvis’ reply?
    Start – Programs – particleIllusion 3 – reset default settings
    Alan.
