Activity › Forums › Maxon Cinema 4D › particle emitter, change direction after 10 meters
  • particle emitter, change direction after 10 meters
    Posted by Mauricio Barrientos on September 10, 2023 at 3:44 pm
    Hello again :
    thanks for the help in advance.
    I am trying to create particles, and have them change direction when reaching a specific point.
    I have tried to place force fields, but I can’t.
    and the fans apply the change but to the ENTIRE SCENE no matter where they are placed.
    I have seen tutorials that DO WORK, but you have to buy [[X_PARTICLES]] and it is very expensive.
    Any solution to this, please?
    then I need the particles to cross [[90_degrees]] …. then cross again at [[-90_degrees]],
    I need particles change direction about 4 – 5 times on same scene, please help !!!
    As I understand, PARTICLES can also follow a SPLINE LINE….. so that they follow a certain course, but I don’t know how to do it, I already tried and couldn’t make the particles obey the direction of the spline line.
    I leave here a couple of photos….
    and in one photo there is a yellow stripe, which is what I need to do.
    Thank you again, I really appreciate it.
    Mauricio Barrientos replied 3 years ago 2 Members · 2 Replies
