Activity › Forums › Maxon Cinema 4D › particle cluster/cloud
  • particle cluster/cloud
    Posted by Jonas Espinoza on May 3, 2007 at 8:32 pm
    i have a bunch of objects i am wanting to populate the sky like clouds, and have some shirts flapping in the wind.
    couple of particle questions:
    1 – is there a way to have a group of objects randomly generated by a particle generator, like particular where frames in a precomp can be randomly generated.
    2 – Ppass is making sense, but for grouping, i am still unsure as to how to assign particles to groups… i understand the TP settings part, but what are some of the nodes that seperate particles out into groups. i have followed some 3d kiwi tutes, but i havent found an intuitive way to select particles…
    3 – to have wind effect objects, such as laundry, flapping in the wind or blowing away, is cloth and dynamics respectively the way to go?
    thanks
    Jonas Espinoza replied 19 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    May 4, 2007 at 7:51 pm
    You should have a browser preset called “TP Multishape Emitter” that will do what you want.
    It all depends on the criteria you want to use. Can be many things, like particle age, velocity, distance, etc. Often you’ll use PGetData for this, in conjunction with a Compare node. When the condition is met the compare node is triggered and you use that to turn on the PGroup node, which causes the particles to change groups.
    ay to go?
    You don’t need Dynamics if you’re just working with cloth objects. Cothilde has its dynamics built in.
  • Jonas Espinoza
    May 4, 2007 at 8:27 pm
    thanks
    i like TP more and more..
    a couple-a more ?’s…
    i am having trouble with some stock models with unlinked textures. is there a window i can bring up to fix and view texture assignments and links etc…
    say – for extruded logos, the fillet cap seems to want to bulge the edges outward. i tried a bevel with the edges loop selected, but it just pushed everything back, almost like a z-axis move. i want kind of a chamfered rounded edge.
    i like how my coworkers 3DS MAX has procedural beveling, edge selections…
    is there a plug in out there that allows for more procedural tagging and rounding options for parametric objects
