Activity › Forums › Adobe After Effects › partical problems with widescreen
  • partical problems with widescreen
    Posted by Toby Heslop on February 5, 2007 at 1:52 am
    I’m using a DV PAL widescreen comp and using partical effect. when I adjust the pixel aspect preview the particals are being streched horizontally.
    how can i stop this so they show correctly round?
    Mylenium replied 19 years, 8 months ago 3 Members · 2 Replies
  • Majorasshole
    February 5, 2007 at 2:42 am
    You could make a larger comp with square pixels and a transparent background and put your particle effects on that. Then nestle that comp as a layer in a your widescreen comp. You can scale the particle layer so the particle pixels stay square
  • Mylenium
    February 5, 2007 at 5:18 am
    Assuming you are speaking of Trapcode’s Particular, work in a square pixel comp (1024×576). Neither of the Trapcode plugins is pixel aspect ratio aware. Same goes for several other standard AE plugins and my also aplly to CC particle effects.
    Mylenium
    [Pour Myl
