Activity Forums Avid Media Composer partially importing an ALE
  • partially importing an ALE
    Posted by Eric Levin-hatz on October 24, 2008 at 8:44 pm
    I’m wondering if it’s possible to partially import an ALE file. What I mean by this is let’s say you want to update a pre-existing bin with new info so that you can re-digitize the bin. Let’s say you have changed the Sound TC’s on the tape- that information goes in the ALE, so you’d need to update it in the bin before you can re-digitize with the new TC.
    Is there an easy way to do this- easier than copying and pasting each TC one by one?
    E
    Michael Phillips replied 17 years, 10 months ago 2 Members · 1 Reply
  • Michael Phillips
    October 24, 2008 at 11:33 pm
    Highlight the clips you want updated, select ALL, import the ALE with the merge option for know sources. Clips will inherit all the information from the ALE – but all fields will be updated so be sure that is what you want first before doing it.
    Michael
    Michael Phillips
