Activity Forums Apple Final Cut Pro Legacy Partial Export
  • Posted by Robert Mckeon on June 8, 2009 at 11:46 pm
    I trying to export 1080i files so that I can work with them in a 720p sequence without having to render new files every time I make a change, but when I export the files – either via batch export or individually – the resulting files all cut off about halfway through. (The IN/OUTs are at the very beginning/end of each file, and I leave “use source in/outs unchecked, anyway.)
    Any thoughts as to why my fcp won’t export full length files?
    Thank you.
    John Fishback
    replied 17 years, 2 months ago
    2 Members · 3 Replies
  • John Fishback
    June 9, 2009 at 5:02 pm
    What kind of drive are you exporting to and how is it formatted?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Robert Mckeon
    June 9, 2009 at 5:47 pm
    Thanks for asking, John.
    I’m exporting to a Seagate Freeagent 500gb hard drive, formatted Mac OS Extended, but I have had this problem – where the runtime of clips or entire sequences is cut off about half way – when exporting to a G Drive RAID as well.
    Bob
  • John Fishback
    June 10, 2009 at 5:06 pm
    Have you trashed prefs and repaired permissions? If not, try that. Also, run Disk Warrior on your system drive.
    John
