Activity Forums Adobe After Effects Expressions Parse a specific line of text
  • Tomas Bumbulevičius
    February 11, 2022 at 11:02 am
    Hey Jeremy, splitting the text by return carriage and picking the line from array.
    var myString = “This is \n some example \n text”;
    var splitArray = myString.split(“\n”);
    splitArray makes your string as [“This is”, “some example”, “text”]
    If you know exactly which line is required, then accessing it by splitArray[X] will do it.
    Where X – index of line in an array (keep in mind arrays starts from 0, not 1)
    So in your given example line2 would be splitArray[1]
