Activity › Forums › Adobe After Effects › Parenting/Rotating issues
  • Parenting/Rotating issues
    Posted by Catherine Chan on August 27, 2009 at 4:14 am
    I’m new to AE and I’m currently working on a kinetic typography project.
    I have four compositions with animated lines of text within a main composition and they’re parented to each previous layer. All the animation (rotate, scale and position) key frames have behaved so far, but for the 5th composition, I need the previous four to rotate 90 degrees clockwise. I’ve placed key frames on the 1st composition (since they’re all linked) before it rotates to keep it in place, then a few frames along, I’ve placed another key frame and rotated the text. Problem is, going to the start of the timeline, it’s rotated everything around as well. How can I stop it from rotating all the other previous key frames?
    Catherine Chan replied 17 years, 1 month ago 2 Members · 2 Replies
  • David Bogie
    August 27, 2009 at 3:05 pm
    I have no idea what you’re seeing.
    The standard answer for such inquires is to Precompose and apply your last set of moves to the downstream setup.
    bogiesan
  • Catherine Chan
    August 28, 2009 at 12:01 am
    Nevermind. Not too long after I posted the question, I found I hadn’t put a keyframe on the rotate layer, and I’d been trying to figure it out for a whole day!
