Activity Forums Adobe After Effects Parenting effects?
  • Parenting effects?
    Posted by Nathan Quattrini on January 19, 2006 at 8:27 am
    I want to have a light sweep travel over several different layers. Is there a way to make the same effect apply to more than one layer? Maybe parenting it or something? Or do i need to dummy the effect on every layer, lining it up to LOOK like only one light sweep effect.
    Filip Vandueren replied 20 years, 7 months ago 4 Members · 3 Replies
  • Spritemaster
    January 19, 2006 at 9:38 am
    Precomp the layers and apply the effect?
    AA
  • Barend Onneweer
    January 19, 2006 at 9:56 am
    Or apply the effect to an adjustment layer on top of the layers?
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
  • Filip Vandueren
    January 19, 2006 at 5:34 pm
    I think he means there are different layers that each have a light-sweep at the same position, not one lightsweep running over all of them together ?
    Just copy the effect and the keyframes, or if you want to keep tweaking and want to absolutely synch the effect, you can create pickwhip-expressions (look in the manual) for the parameters of the “child layers” effect to the same parameters on your “parent” layer.
