Activity Forums Adobe After Effects parenting and masks.
  • parenting and masks.
    Posted by Ross Kidd on October 17, 2008 at 7:07 am
    I have a parent object that I want to mask. The problem is when I mask it the child object is not masked. Is there a way to add the child to the mask of its parent?
    Ross
    Mark replied 17 years, 11 months ago 2 Members · 3 Replies
  • Mark
    October 17, 2008 at 10:25 am
    Have you tried precomping and adding the mask in the Precomp ?
    mark
    Mark Harvey
    Senior Editor
    Le Réseau des sports
  • Ross Kidd
    October 17, 2008 at 12:02 pm
    Only 2nd ever AE project and I do not know what precomping is do you have a link to a tutorial?
    Ross
  • Mark
    October 17, 2008 at 1:12 pm
    Precomping is creating a new comp, dropping existing footage into that comp, and then bringing that comp into the existing comp….this can be acheived easily by selecting layer(s) and going to the layer menu and selecting precompose. The advantage is that you can make changes in the precomp, and still make changes to the precomp as a layer….
    This is pretty basic AE stuff….not to be rude, but I would suggest reading the manual, as this type of stuff is well explained…and the manual will help you get the most out of the program.
    Mark
    Mark Harvey
    Senior Editor
