Activity Forums Adobe After Effects Expressions Parenting a scale layer of one layer to position of another
  • Parenting a scale layer of one layer to position of another
    Posted by Sean Platt on March 14, 2016 at 10:14 pm
    Hi There. I was hoping someone could explain what I need to do here. I have a layer that has a wiggle expression for just the y-axis POSITION property. I have another layer that needs to wiggle the x-axis SCALE property In SYNC with the y-axis position property. Any suggestions (and the “why” behind it all so I can help put the pieces together in my head for future) would be most appreciated. Thanks!
    Sean Platt replied 10 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    March 14, 2016 at 10:36 pm
    One way would be to put an amplitude = 1 wiggle on a slider control:
    wiggle(1,1)
    and then use that as the basis for the wiggles on the other properties (adding a multiplier for the proper scaling). For position, it might look like this (assuming you haven’t separated dimensions):
    w = effect(“Slider Control”)(“Slider”);
    value + [0,w*100]
    and like this for scale:
    value + [w*50,value[1]]
    Try it–you’ll see how it works.
    Dan
    Oops– the one for scale should be:
    value + [w*50,v0]
  • Sean Platt
    March 15, 2016 at 5:19 pm
    Dan, thanks so much. This worked perfectly. Slowly putting this (expressions) all together in my head 🙂
    Again, thank you for taking the time to help!
