Activity Forums Adobe After Effects Expressions Parenting a Puppet Pin
  • Parenting a Puppet Pin
    Posted by Harrison Willett on April 11, 2008 at 2:19 pm
    I have built a character rig that is just comprised of parented Solids. The character’s tail is parented to the body and the tip of the tail is parented to the tail. I am planing on making the solids invisible and adding an expretion to puppet pins on a different visible tail layer so that the pins will fallow the parented solids.
    is there a way to do this?
    i am getting stuck because the parented objects location doesn’t “change”
    Is there a way to tell the pin the location in the comp of the solid?
    Harrison Willett replied 18 years, 4 months ago 2 Members · 4 Replies
  • Filip Vandueren
    April 11, 2008 at 4:06 pm
    yep: you need two “layer space transform”:
    one to transform the position of the anchorpoint to a position in the comp,
    a second one to transform that position to a position on the Puppetedlayer:
    Puppet Pin 1 – position would get:
    l=thisComp.layer("solid 1");
    compPos = l.toComp(l.anchorPoint);
    layerPos = fromComp(compPos);
  • Harrison Willett
    April 11, 2008 at 4:41 pm
    Ok I typed in:
    1=thisComp.layer(“TailPoint 1”);
    compPos = 1.toComp(1.anchorPoint);
    Under Tail – Puppet Pin 2
    After Effects warning: Can’t appear on the left hand side of an ssignment, because it is read only
    Line 1
    Property:’Position’
  • Filip Vandueren
    April 11, 2008 at 4:50 pm
    The first character should be a lowercase L, not a 1 (one), same thing in the other lines.
  • Harrison Willett
    April 11, 2008 at 4:58 pm
    thank you!
