Activity › Forums › Adobe After Effects Expressions › Parent expression using Layer control effect
Neil Stubbings replied 16 years, 3 months ago 3 Members · 15 Replies
Dan Ebberts
June 22, 2010 at 10:08 amProbably something like this then:
target = effect("Layer Control")("Layer").position; //select which layes it will follow
seedRandom(index, true);
delay = random(effect("Slider Control")("Slider"));
delta = target.valueAtTime(time - delay) - target.valueAtTime(0);n = 0;
if (numKeys > 0){
n = nearestKey(time).index;
if (key(n).time > time){
n--;
if (n == 0){
t = 0;
}else{
t = time - key(n).time;
}if (n > 0){
v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
amp = .05;
freq = 4.0;
decay = 2.0;
value + delta + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
}else{
value + delta
Dan
Neil Stubbings
June 22, 2010 at 10:18 amHi Dan
Thanks so much for looking into this!
Buuuut, unfortunately it does not seem to work (i’ve gotten this far by myself before 🙂the layer with the expression follows the leader layer, but has no springy motion to it.
Is it because the expression needs keyframes on its layer in order to calculate the springy motion?—
Neil Stubbings
Graphic Design | Motion Graphics
https://www.stubbings.ch
Dan Ebberts
June 22, 2010 at 10:23 amYup. That’s what I meant when I asked about what was supposed to trigger the springy motion. The way you have it set up now, it would be keyframes on the property with the expression.
Dan
Dan Ebberts
June 22, 2010 at 4:55 pmThis might be closer to what you’re looking for. It’s triggered by the keyframes of the leader:
if (target.numKeys > 0){
n = target.nearestKey(time-delay).index;
if (target.key(n).time > time-delay){
n--;
if (n == 0){
t = 0;
}else{
t = time - delay - target.key(n).time;
}if (n > 0){
v = target.velocityAtTime(target.key(n).time - thisComp.frameDuration/10);
amp = .05;
freq = 4.0;
decay = 2.0;
}else{
value + delta
Dan
Neil Stubbings
June 22, 2010 at 6:21 pmoh wow!
it works great! this is exactly what I was looking for!
thanks a lot, Dan!
Neil Stubbings
