Activity Forums Adobe After Effects Parent an X,Y location to another objects rotation
  • Parent an X,Y location to another objects rotation
    Posted by Steve Yager on July 4, 2018 at 3:20 am
    I’ve got a piece of text rotating and I want to parent an object’s XY location to the corner of one of the letters spinning around. It’s important that I don’t parent the whole object because I don’t want it to rotate. I just want it to match the XY location as the letter is rotating. Thoughts?
    Kalleheikki Kannisto replied 8 years, 2 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    July 4, 2018 at 6:59 am
    You can parent the whole object, then pick whip the rotation value of the parent for the child object and make it negative with a minus sign at the beginning of the expression. This will result in the desired behavior, since the child will be rotated in the opposite direction by the same amount.
    Senior Graphic Designer
