parameters change
Hello,
I am new to Cinema 4D and I have several questions:
1. I cannot find a way to modify some parameters, like the number of copies in the “duplicate” function, for example. Once the function is applied, is there a way to modify its parameters?
2. How can I link some object properties to the “user data” values attached to the same object (like the dimensions of a cube, for example).
3. Why the “add user data” option is grey in the “duplicate” function?
4. And finally, is there a way to attach an XPresso constant to the null object unifying the “duplicated copies” in a way that it is used as a parameter for the duplication itself?
Thank you!
