Activity › Forums › Adobe After Effects › Paralax effect/matching background movement to foreground
  • Paralax effect/matching background movement to foreground
    Posted by Sam Harris on November 25, 2009 at 2:02 pm
    Say I have a greenscreen foreground that is moving around and can be tracked easily enough, what is the best method to apply that tracking information to the background so that the movement is consistent with what it would look like in reality if the background was a bit further away from the camera than the foreground?
    I’m guessing that the background with move in the same directions but just less so… If I am correct in saying this, what would be the best expression to use to achieve this?
    Thanks guys
    Anders Hattne replied 16 years, 10 months ago 4 Members · 3 Replies
  • Walter Soyka
    November 25, 2009 at 2:59 pm
    I don’t think you’d need to write an expression; you could do this with 3D layers.
    Place your foreground and background layers like you normally would. Parent the background to the foreground, and make them both 3D. Add a camera. Adjust the anchor point of the background in the Z-axis only.
    You will control the parallax effect through the camera settings and the z-anchor on the background.
    Walter Soyka
  • Todd Kopriva
    November 25, 2009 at 4:17 pm
    What you’re referring to is a simple version of what is often referred to as ‘camera mapping’ or ‘camera projection’. See this page for a link to a free chapter from Mark Christiansen’s book that describes how to do this sort of work.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Anders Hattne
    November 25, 2009 at 10:17 pm
    There is a bit of expression you can use in this PDF.. took me a long time to find it.
    Title is “Simulate realistic motion (motion parallax)”
    https://video.ucf.edu/knowledge/reference/pdf/adobe/aft6parallax.pdf
    http://www.ardillamedia.com
