Activity Forums Maxon Cinema 4D paper simulation stick, peel off then fall
  • paper simulation stick, peel off then fall
    Posted by Jason Jantzen on December 11, 2013 at 10:26 pm
    I’ve tried adding a bend deformer and then enabling the dynamics right when the curl is at it’s peak, but it always pushes away from the object that it’s “mounted” on. I have a cube as my sign backing and plane as the sign paper which I want to fall off the sign, but I don’t want it to just fall off, I’d like it stick toward the bottom of the sign to the cube and then sort of peel off and fall away. Any ideas?
    Jason Jantzen
    vimeo.com/jasonj
    Jason Jantzen replied 12 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
